Fillet between planes
scott_jones724
Member Posts: 3 ✭
First of all, thank you to all who volunteer your time to help new users like myself.
I am trying to draw a washer bottle from a classic car. Here's a photo of said bottle:
For the most part, it a simple hollow cylinder. However, see how it has the smaller diameter band? That's one part that is giving me fits.
The method I have been trying is to create three different size circles for the three sections, then extruding them. However, I need to soften the transitions on the band, so was trying to use a fillet. I can't seem to figure out how to that -- it won't "connect" the two different plans, and instead the fillet goes the wrong way, as can be seen here:
Here's a link to my document:
https://cad.onshape.com/documents/e037e1f581983a00fa11838c/w/9a45b62a443b95884deb2769/e/9186e22a1739eee1ed4d6173
Thanks for any help!
Scott
Scott
Scott, you will need to edit the extrusions and choose the ADD option rather than NEW.
That will join all the cylinders into one solid and you can then apply the fillets as needed.Onshape Senior QA Engineer0
That will join all the cylinders into one solid and you can then apply the fillets as needed.Onshape Senior QA Engineer0 -
Dave is correct. A fillet will not cross parts. It will place fillets on the edge of a part. Here is one method of many to generate what your looking for.
https://cad.onshape.com/documents/ca8b29bfae935ed91b143059/w/064da7278c531c6fa5e9faae/e/16f453b90fc8f4d2c66f95bd
Thank you! Wow, seemingly so simple and elementary, yet so important a concept. Duh... ADD to the part!
Using this knowledge and a bit more I picked up, I was able to construct what I believe is a faithful reproduction of the bottle:
(the message got posted twice -- there was no indication that the comment had been submitted, and so I thought it was in error, which led me to post again)0
