Plumbing parts library
jeff_mcaffer
Member Posts: 98 ✭✭✭
I'm designing up an hydronics (in-floor water-based heating system) and would love to do it in onshape. I can't be the first person to do plumbing and sort of hoped that there would be a library of parts I could assemble but I don't see anything (or am not good at looking for this stuff). Any pointers either to such a library or how to look for one better?
Hi @jeff_mcaffer, here are some part library apps from the Onshape app store that should help you out:
https://appstore.onshape.com/apps/Manufacturers%20Models?sort=featured
If none of those work, I prefer using McMaster-Carr. You can download and import the parts you need. If you do go this route, and use this process often, it is possible to create your own library via Onshape documents.
RENDERCAD
rendercad.ai - Photorealistic product rendering.
