Annotation Array is not displayed correctly at PartStudioData
georg_von_vietinghoff
Member Posts: 9 ✭✭
The values are displayed correctly, but not the part. Ideally, the configured part name would be displayed here.
Does anyone have an idea or solution?
here is my code:
Many thanks and merry christmas
George
here is my code:
annotation { "Name" : "Bohrung setzten", "Item name" : "Bohrer", "Item label template" : "X #xri: Y #yri: #bohrer"}
definition.myBohrer is array;
for (var Bohrung in definition.myBohrer)
// Nested parameters defined here, as e.g. widget.myParameter
annotation { "Name" : "X-Richtung" }
isLength(Bohrung.xri, LENGTH_BOUNDS);
annotation { "Name" : "Y-Richtung" }
isLength(Bohrung.yri, LENGTH_BOUNDS);
annotation { "Name" : "Bohrer auswaehlen" }
Bohrung.bohrer is PartStudioData;
George
PartStudioData parameters without the dialog is opened display the name of the Part Studio, not the Part. If you would like it to behave differently, I would suggest raising an improvement request!0
it works
and that's it, why it works:
var configname = Bohrung.bohrer.configuration.Konfig_Bohrungenvar bennenung = l_x_pos/meter*1000 ~ "/" ~ l_y_pos/meter*1000 ~ "/" ~ l_z_pos/meter*1000 ~ "/" ~ configname;setFeatureComputedParameter(context, id, { "name" : "bn", "value" : bennenung });
it accesses the Featurescript ID and reads it out. Since this is all in a "map", you can also get to it.0
