Input FeatureList parameter via API
isaac_trumper
Member, Developers Posts: 2 ✭✭
I am attempting to use the FeatureList object in a feature script array that allows the user to select a set of previously defined features and then based on the ordering of those features more action is taken. Using this from within the Onshape UI makes sense to me, and the discussion here is helpful for working with the object in feature script. However, my question is how to define this as an input when creating the feature via the API. Specifically, the lambda function definition is confusing to me, as the client calling the API would not have the function definition.
I am also wondering if there is a better way to do what I am trying to accomplish, for instance, is there a way to just define a set of Ids that reference specific features without the lambda? Thanks!
