Assembly Structure Noob
I have been on NX/UGII for 35 years, since retiring from Siemens, without a complementary copy of the software, I've been struggling with FreeCad and its assembly module. If you can call it that.
I've been trying to use OnShape but the process is so different I don't know where to start... So my question is I have a bunch of FreeCad bodies that I can export a STEP assembly blob model containing all my parts. OR is it better to import single stand alone bodies?
I don't know the workflow to use them after importing these, get them to where I can edit them, add to them, or design around them, reassemble them to prove my concept.
My confusion is what's first with these imports?
Is there a workflow cheat sheet. LIKE:
1.) Import blob as separate bodies, or ??
2.) How to add them to the Studio,
3.) Best practices using those imported bodies
4.) ? help :-)
  • S1monS1mon Member Posts: 3,980 PRO
    I'm guessing you're on a free account? I had almost as many years of Pro/E and Solidworks before fully making the transition to Onshape. It will take some getting used to, but to me it's mostly an improvement. Even though you're very experienced, I would highly recommend that you go through some of the training. There's a lot that's available for free.
    https://learn.onshape.com/catalog
    https://learn.onshape.com/learn/learning-path/onshape-fundamentals-cad
    As a quick answer to your questions, it really depends on what you want to do with the parts. Typically a bunch of parts which are intimately connected with design intent and shape want to be in a single part studio. Things like hardware or other off-the-shelf components most likely want to not be in the part studios that are being used for custom project related parts, and may want to be in separate documents.
    https://learn.onshape.com/courses/onshape-essential-tips-best-practices-when-importing-data
    Imported parts can be manipulated with direct modeling techniques similar to what you're familiar with from NX. As you're most likely aware, Onshape is based on the same Parasolid kernel as NX.
    https://learn.onshape.com/courses/direct-editing
