Unable to flatten filled & thickened surface made entirely of splines
c_h367
Member Posts: 4 ✭
I'm trying to create a cup-/dome-like shape using splines, but it's resulting in this weird wobbly/uneven-ness to the bottom surface. I'm using a Fill followed by Thicken to create a non-zero-width wall for 3D printing. The Fill produces an error unless I switch it to Sampled, but that rendering looks completely fine, until I add the Thicken. It produces the cupped bottom edge as indicated in my screenshot.
I had quite a bit more weirdness around the back and front just using Fill, due to influence from the spline control points, but ensuring the controls were at 90° angles helped resolve it (and improved the wobbliness a bit).
Does anyone know how to flatten this surface out? Here's my model:
S1mon Member Posts: 2,808 PROThis can be much more straightforward. You can make the main shape solid with one more fill, and then shell can be used to thicken to the outside, while keeping the bottom flat. The cylindrical part doesn't need so many steps to add onto the main body.
1 way to fix is move face to extend part past where you need it then use an extrude/subtract to clean up.
https://cad.onshape.com/documents/fcfbd10383d5605fd32ed846/w/c5296aeece6364080b1bb8e6/e/7e5bf2994749c72f3d48d439
I'm not a surfacing expert at all, but you could try a few things:
- make sure the ends of the splines are perpendicular to the base plane before creating your surface.
- You might be able to use "replace face" on the bottom surface to flatten it out.
- You could extend your surface further bigger than it needs to be (extend it further downwards) and then trim the body after the thicken operation.
Someone else may be able to provide better guidance on the right way to approach this, but those are my thoughts.This is very helpful as a beginner, thank you!
