How to move constrained point?
josh_mccullough080josh_mccullough080 Member Posts: 24
I'm creating a ratchet, and need to extend all of the "teeth", each of which are constrained to be equal (shown here by small green line). I want to extend the dimensioned tooth downward as shown by the red circle/arrow. However, I cannot move the point. When I try, it just disconnects the leftward line from the downward line (red arrow).
Here's what happens when I change the dimension:
I'm new here, so any advice on how to properly constrain this thing is welcomed!
  • robert_scott_jr_robert_scott_jr_ Member Posts: 767 ✭✭✭
    Hello Josh. Please post a link to your document. - Scotty
    @josh_mccullough080
    Maybe you would find this approach something you would want to use
    And because Onshape is a PARAMETRIC CAD program, it makes it easy to modify
  • josh_mccullough080josh_mccullough080 Member Posts: 24
    @steve_shubin very cool! I will give that a try.
    Update: Got it with your excellent visual guide -- thank you!
    @josh_mccullough080
    I’m glad to hear the GIF helped !
  • steen_pedersen968steen_pedersen968 Member Posts: 19
    can u put up the gif I Got same problem maybe i Can learn it there 😀
    Hello. From Josh's images and description, it's apparent that the 'left line' does not move with the shorter, more vertical line when that line's dimension is changed is because the end points of those two lines are not coincident; they are not connected to each other. Adding a coincident constraint to the end points would rectify that. - Scotty
