cut a curved object
in General
the red line is meant to be where i want to cut it
https://cad.onshape.com/documents/ac29ebe72c2d16e89f119140/w/2f51355e446392ac371ee0df/e/97050010fcc507ccfc33e4f8?renderMode=0&uiState=63b6037ed9f11e4032d2f00f
https://cad.onshape.com/documents/2867c217c535b4437152a5ea/w/3e127d70e2305ff120e5179a/e/1669ba8c64ce9acf4a8dfdfa
@S1mon's approach will be the easiest. It should go something like this:
- Trace your profile in a sketch. This should be easy, since your spiral seems to have been created with arcs instead of a spline.
- Use the Sheet metal model feature to extrude the sketch as a sheet metal part.
- Once there is a sheet metal part, you can now use the Sheet metal table and flat view button on the right side of the screen.
- Create a sketch in the flat view of the sheet metal part.
- Extrude the sketch from the flat view to remove the material.
- When finished, use the Finish sheet metal model feature.
https://cad.onshape.com/documents/079fbfca6d20a66611d69232/w/ed3d289b7630d0d325721cc9/e/aa9163d12ad477bba21961b0?renderMode=0&uiState=63b709871ccabb3fd85f0db1Learn more about the Gospel of Christ ( Here )
