Querying faces/objects located on one side of a plane
yurii_haiovyi
yurii_haiovyi Member Posts: 8 ✭
Is there any way to query faces that are located on one or another side of a given plane? qSplitBy doesn't return unaffected faces from faceTargets query, so there's no way of knowing what's where.
Thanks!
  • mahir
    I'm hoping there is a simpler method that someone can come up with, but I have a couple ideas.
    You could use a dummy plane (PlaneB) that is just slightly offset to the wrong side of the original plane (PlaneA). Then, for each object of interest you can perform evDistance to both planes. If an object is closer to PlaneA than PlaneB, then it's on the right side.
    Alternatively, you can create a giant dummy volume bordering your plane and query for all objects that intersect with it.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,959 PRO
    edited January 2023
    Here is a similar approach to what @mahir was suggesting. This approach takes the centroid of every part and checks if it is on the positive side or negative side of the plane. The key here is taking that centroid vector and getting the Z value from it. Vectors are stored in array format like this [x, y, z]. To get the Z value from it would look like this centroidVector[2]. Then you can determine if it is positive or negative relative to the measuring plane.
    I have placed this inside of a function so that all you need to do is import the function into your project to be able to use the function in your feature definition.
    https://cad.onshape.com/documents/3b7cb6cdfff8caa4fde98d8e/w/e656ed116b6492f6e01625fd/e/eadcf365f911e7410b5d0e23?renderMode=0&uiState=63bd72f62e5bc928d81b9c1b
    Place this at the top of your FeatureScript:
    import(path : "3b7cb6cdfff8caa4fde98d8e/9d6b44408c25f318c0d42e1b/36ee53f33bea2a368d4066a5", version : "7ce6f473ce4f41d1a7b55134");
    Then, you can use the function qThisSidePascoe() like this within your feature. This will return the entities on either side of the plane you give it:
    const entities = qThisSidePascoe(context, query, plane, oppositeDirection);
    If you don't want to import the function and would rather do it manually, here is how you can do that:
            var everything = qAllNonMeshSolidBodies();
            everything = evaluateQuery(context, everything);
            const evalPlane = evPlane(context, {
                    "face" : definition.plane
            var entities = qNothing();
            for (var i = 0; i < size(everything); i += 1)
                const centroid = evApproximateCentroid(context, {
                            "entities" : everything[i]
                const localVector = worldToPlane3D(evalPlane, centroid);
                const sign = definition.oppositeDirection ? -1 : 1;
                if (localVector[2] * sign >= 0)
                    entities = qUnion([entities, everything[i]]);
            debug(context, entities, DebugColor.CYAN);
  • javawizard
    javawizard Member, csevp Posts: 13 ✭✭
    Looks like a new qInFrontOfPlane query was introduced in August of 2024 that does this: https://github.com/javawizard/onshape-std-library-mirror/commit/1fbd9a0390074a48ad505eb6fecec12609c7abe4#diff-9224234481572f0168b1ceda65b5688892aebe36cd04d2b65a9d4bcce71c4026R1885
    I'm using it to do exactly what you're talking about: split a bunch of parts by a plane and separate out the results, including parts that weren't split by the plane at all. It works just about how you'd expect:
    const partsToSplit = definition.partsToSplit;
    const splitPlane = definition.somePlaneOrPlanarFace;
    const evaluatedPlane = evPlane(context, { "face" : splitPlane });
    opSplitPart(context, id + "split", { "targets": partsToSplit, "tool": splitPlane });
    const front = qInFrontOfPlane(partsToSplit, evaluatedPlane); // includes both split and unsplit parts
    const back = qInFrontOfPlane(partsToSplit, flip(evaluatedPlane)); // ditto
