Shaded Views API Transformation Matrix Zoom
Hugh_GoodbodyHugh_Goodbody Member Posts: 41 PRO
I am trying to get the shaded views image of a part which is zoomed to its extents. I am using the shadedviews api call.
I have constructed a transformation matrix but the image is very small, does anyone know the best way to amend the transformation matrix so that the image is zoomed to its extents? I do have access to the min and max corners of the bounding box.
Thanks in advance.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,635 PRO
    @Hugh_Goodbody
    From my very rudimentary knowledge, the "pixelsize" value is that defines the zoom and the matrix only affects the "direction"/"pan".
    If you set "pixelsize" to 0 it will fill the image with the model.
  • Hugh_GoodbodyHugh_Goodbody Member Posts: 41 PRO
    Perfect, thanks very much Eric.
