how to split a ring in four equal parts
didier_pecherdidier_pecher Member Posts: 3
Hello there I'm a biginer on this wonderful program, and I'm stuck with the following.
I design a ring that I would like to 3D print, but I need to cut this ring in 4 equal parts.so I will guet 4 sectors.
I try to use the tool split but somewhere I guet lost. Can sombody help me with this
  • klaus_krämerklaus_krämer Member Posts: 93 ✭✭✭
    As I can only guess what kind of ring you made a quite simple solution:
    Draw two perpendicular lines intersecting in the center of your ring. The lines cut your ring into 4 equal sized parts. Then create 4 solid parts separately ...
  • MichaelPascoeMichaelPascoe Member Posts: 2,813 PRO
    edited January 2023
    Here is one approach that will do this:
    Split will work, however Thicken might work better in this case so that you have tolerance for the pieces to fit together in the real world.
    • Use a sketch to determine one of the split profiles. I suggest a shape that is self aligning.
    • Extrude the split sketch as a surface.
    • Circular pattern the surface.
    • Now, you can either use the Split tool, or the Thicken remove. Selecting the surfaces from the part tree on the left is an efficient way save clicks.
    https://cad.onshape.com/documents/0fc96d60ee7ce88b06d63fb3/w/c21c81088d96bb87338b76f3/e/bcb36f417b0ffaaa545b5b4f?renderMode=0&uiState=63bea7ee2b0e5d215bc1229e
    RENDERCAD
  • John_vd_WerffJohn_vd_Werff Member Posts: 66 PRO
    Greate little tutorial! I keep learning new tricks.
