I need some simple instructions
jack_erhart
Member Posts: 140 ✭✭
in Drawings
I have two round objects that I need to join together. One round is larger than the other. And I need the transition from one to the other to happen on the top side of the two rounds with the bottom remaining flat, as seen from a provile.
Could someone please instruct me on what feature can accomplish this, and how?
Thank you for your help.
If the parts are not touching, use Loft. This will require splitting the parts in some way so you have something to loft from and to.
If the parts are overlapping, use Fillet or Loft.
Please share a link to the document for specific instructions.
RENDERCAD
rendercad.ai - Photorealistic product rendering.
The Loft feature is what I stumbled across, and I think I got it to work for me, but I'm practicing more to try and get better at it. Here is the link you requested.
https://cad.onshape.com/documents/ada7021bb3ade9fe7cbbc2a1/w/e1d395f32468e5bc42466da1/e/b7b7c7546b944914288a03e5
Thanks again for your help.
