No infill when slicing with Cura
gibet_bgibet_b Member Posts: 6
Hi,
I'm becoming crazy, I don't understand why I have not infill in Cura (or Prusa Slicer) :
I tried differents settings, but I guess the problem is with my model...
Here is the model : https://cad.onshape.com/documents/7e977f5817173f55f0ed8245/w/48f0411e22340448dd6b079e/e/08a0062785eb728074e50a2d?renderMode=0&uiState=63d180dac069dd4e83a5a0a0
Do you have an idea ?
Thanks a lot
  • _anton_anton Member, Onshape Employees Posts: 515 image
    The walls are hollow and very thin - only the yellow regions you see here will be printed. I think, for the purposes of printing, you'll need to make the model more solid than it is. You'll also likely need supports.
  • gibet_bgibet_b Member Posts: 6
    Thanks.
    I just find my mistake : it was the last shell which included all the part...
    Thanks.
