Do objects cut through when they intersect?
I'll hook up an image, for example, we have a pole going through a solid rectangle, will the pole cut through the rectangle automatically when printing or when put in a slicer?
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 431 PRO
    Hi, no it does not automatically cut through. You can use the bolean feature to intersect both parts and cut away the material you want
    Best regards,
    Axel Kollmenter
