How do I round this edge?
ravindra_wankar
Member Posts: 6 ✭
Hello,
I'm quite new to 3D Cad and have a really basic question. How do I round the edge of this shape to look like the second image? The shape was created using a spline and the rotate tool. I then used the thicken tool to make it thick. I first tried to curve the edge of the spline and then rotate it but I couldn't do that. The spline was created using the Read CSV feature so I couldn't get that into a sketch.
Thank you for your help in advance.
You can access the project here https://cad.onshape.com/documents/34a27c9c83a645d5da0e6b1f/w/08cccdb6cef7f378b40bb455/e/40eb5dd7dd83a065753099f6
@Hans_Leirvik_1 looks like your linked document is private, I wasn't able to access it.
Hi @ravindra_wankar, Welcome to Onshape! Try something like this:- Edit Sketch 1 and constrain your rounded end.
- Edit Revolve 2 so that it has the new geometry.
- Edit Thicken 1 so that it thickens the new surface.
https://cad.onshape.com/documents/d8dd250ca10003265a3be6bc/w/cba15bb7db69daa6bcdf4957/e/cdf2e91338efe0970dcdf8fd?renderMode=0&uiState=63e2504b27961813dc34f575
◉ RENDERCAD - Photorealistic product rendering.◉ CADSharp - Professional CAD + software consulting.
▚▞▚▞▚▞▚▞▚0
▚▞▚▞▚▞▚▞▚0 -
@Hans_Leirvik_1, I'm using the free version and it says all my documents will be public.
@MichaelPascoe, thanks a lot. I tried that and it works well.1 -
I just realised that the link to the document posted by @Hans_Leirvik_1 was not my doc but meant to be a solution. I too wasn't able to access it.
1
