Text after Reference Dimension
in Drawings
Good morning,
I was putting in overall dimensions for an assembly drawing I'm working on. For my dimension I want to have the format for the dimension to be "(in[mm]) AOL". However, when I was editing the dimension and placing it on the last text input box on the dimension window but Onshape automatically moves the bracket to make the dimension look like "(in[mm]AOL)". Is there a way that I can work around that to make the text go outside the box? Or would I just have to add a new text with AOL after the bracketed dimensions? Thank you for your time!
