Configuration variables vs configurations?
S1monS1mon Member Posts: 3,886 PRO
Is there a way to build a part studio using configuration variables, and then have a list of configurations to choose from (not an infinite variety)?
For example, let's say I have a part called "box" which is simple cube extrusion. I set the #sideLength as a configuration variable with a default of 50mm and a range of 10mm to 100mm. Then I want to have a "small", "medium" and "large" sizes (let's say 10mm, 30mm, and 90mm for #sideLength).
Other than going back in and getting rid of the configuration variable and just configuring a regular variable, is there a way to do this? I like the flexibility of configuration variables, but I also like the idea of having a simple list of configs to choose from. Is this something I can do with a derived part?
  • S1monS1mon Member Posts: 3,886 PRO
    @eric_pesty
    THANK YOU. I was about to try derived models as my next step to see if this is indeed how it works. Your example makes the power and flexibility of this very clear.
    I have to say that configurations in Onshape are incredibly powerful in ways that I haven't seen in other CAD systems. Maybe I haven't investigating the alternatives enough recently.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,509 PRO
    No worries, you were on the right track with deriving and I happened to have an example ready to go from a previous discussion!
    And yes this works very well and we have used it successfully a number of times for things like:
    - Pop rivets we have a master model and then derive that in to create different sizes that we can show in the both "unformed" and installed (in different thickness materials).
    - Families of electrical terminal blocks/headers etc.
    - Rubber grommets instead of downloading a various STEP files
    - Electrical contacts like ring or fork terminals
    - Etc
    My biggest complaints with configurations in Onshape are the fact that you can't make two configurations of something appear as a single item (in BOMs of for releases), and the fact you can't prevent "incompatible" combinations of inputs. Other than that it quite flexible and really easy to use (and maintain, which was always a huge pain in SolidWorks where you spend half your time having to double check and fix broken configurations...)
    Agreed about the missing things in Onshape, and about the pain of Solidworks configs. I spent more time maintaining Solidworks configs than I did using them. Using configs with inserted models (equivalent of derived) was very flaky.
  • EvanReeseEvanReese Member, Mentor Posts: 2,776 PRO
    I ended up doing a user group presentation on some of the powerful hidden functionality of configurations, maybe I should make a YouTube video on it sometime.
    Please do!
  • shawn_crockershawn_crocker Member, OS Professional Posts: 925 PRO
    I use the derive method usually as well. I make a configured master studio that potentially has lots of parts. Then I derive each part into its own studio so that it can have its own set of configuration inputs that are suitable to that specific part. I don't like using parts from a configured multipart studio because everytime you insert a part into an assembly, you potentially has loads of inputs to consider when possibly only one input actually has a geometric impact on that particular part. Onshape configs are a life save for the type of designing we do.  Sheet metal products that are majorly made from standard parts and assemblies with a few customized options sprinkled in.
  • julian_julian372julian_julian372 Member Posts: 20 ✭✭
    This was the example on mastering configurtions i was looking for.
    onshape needs to incorporate this post / example into there configurations tutorials.
  • romeograhamromeograham Member, csevp Posts: 737 PRO
    We've settled on this method as well - doing "design" work in a configured part studio, deriving each configuration into its own part studio tab - and then releasing from there. This makes it much easier for casual viewers of the document (say, project managers or other engineers that are not designing these parts) to see what each part is. Then, these parts are used in assemblies and drawings.
    This means that the trail of breadcrumbs from a top-level assembly goes through these clean, simple part studios (with a single part) down to the messy, configured, multi-body design Part Studio.
    Also much easier to move parts / tabs / drawings in & out of documents, since they already live in their own tab.
    You'll need to add any sketches you want in your drawings to the single part studio tab (since they won't show up in a drawing even if you derive them in to the part studio).
