circular pattern defining overall diameter based on count
Trying to create a timing gear of rough overall diameter based on how many teeth will come close to that diameter. For example, I need a roughly 203mm diameter gear, knowing the tooth spacing is 5mm I created a circular pattern of 124 tangent circles that fits within the rough 203mm diameter. The count defines the overall final diameter of the gear. I want to use the count number (124x) to drive a circular pattern feature to cut the teeth. Variable studio does not allow the use of the count in a sketch pattern to drive anything. It can be solved by working backwards but that can't be the only solution. It seems to come to odds with Onshape's "deterministic regeneration architecture".
Hi @John_Stutz, here is one approach you could try:
- Within your sketch, constrain only 2 circles to represent the pattern.
- Dimension the angle between them with the calculation 360 / qty.
- You can then use the circular pattern feature to pattern the holes out side of the sketch if needed.
https://cad.onshape.com/documents/47c994f5a5c902fbfbfca2d8/w/fcf6de2db517cec141f3520a/e/108806d7fa108ccf4b5bc2de?renderMode=0&uiState=63eb88165825ce64cdc790e4Learn more about the Gospel of Christ ( Here )
