New Feature: Match Closest Array Element
imants_smidchensimants_smidchens Member Posts: 69 EDU
Ever been modeling a configurable part when you realize that different materials, profiles, etc result in different options for length, thickness, diameter, or something else?
Ok in hindsight that's a pretty specific issue to have, but here's a feature that solves those issues regardless:
https://cad.onshape.com/documents/d275f0aa6c54b39d90c74962/w/e885bb4824259a9718e49d84/e/36e1d31aa7ce39ef92db4201
  • MichaelPascoeMichaelPascoe Member Posts: 2,775 PRO
    edited February 2023
    Nice, I've been trying to think of some useful ways to use these array variables. This would be tough to do without this. Ty for sharing!
  • chadstoltzfuschadstoltzfus Member, Developers, csevp Posts: 168 PRO
    Custom features + configurations = a whole new way of modeling
    chadstoltzfus@premiercb.com
  • S1monS1mon Member Posts: 3,985 PRO
    @imants_smidchens
    Based on this comment, if you're ever going through a very large array, you might want to modify
        for (var i = 0; i < size(arr); i += 1)
    to be
        var size = size(arr);
        for (var i = 0; i < size; i += 1)
    I also wonder if any of your comparisons would benefit from using tolerant flavors?
  • imants_smidchensimants_smidchens Member Posts: 69 EDU
    S1mon said:
    @imants_smidchens
    to be
    Oo - that's clever. Thanks for linking to that discussion! The performance-optimizing-gremlin part of my brain is quite appreciative. Definitely looking into tolerant flavors for a potential improved v2. This got me thinking, heck, might even try doing some regex logic to match similar/identical strings...
