Simscale and Onscale import from Onshape - project list missing?
david_scott322
Member Posts: 5 PRO
Hello, it used to be different, once upon a time...
When I "Import from Onshape" into these Apps, the folder tree is empty. In the case of OnScale, if I search for just a single letter (without <CR>), the project names that contain that letter will show up in a folder.
I didn't do exactly the same test in Simscale, but it worked the same with 2 letters.
I'm using a Mac, latest OS update.
It's the same behavior in Chrome and Safari.
Screenshots below, hopefully.
Onscale: initially nothing, then type "f" and a Document folder appears, which I can expand to see 3 projects that contain the letter f.
Simscale: also, initially nothing, then type "in" for some onshore documents to appear.
I remember the behavior seemed to be different before (I'm not a consistent user of FEA). The two things in common are *Mac, and *Onshape.
Thanks in advance,
Dave
Thanks in advance,
Dave
