Sheet metal flat pattern through the API
The list of parts via /parts/ endpoint will contain both the folded and flat patterns of the parts, with the property isFlattenedBody.
1 -
@caden_armstrong
Thanks for this answer! I hadn't noticed it until now as I am suddenly in need of actually getting flats now.0 -
@shawn_crocker
@caden_armstrong2
How can I export the flat pattern as dwg/dxf after finding the related IDs of the Flattened View. I couldn't find the endpoint for that.
@severin_schranz895
You are supposed to be able to use this end point. https://cad.onshape.com/glassworks/explorer/#/Document/export2Json. I played around with it a few months ago but there are a lot of parameters and I was not sure what they all do. I couldn't get it to work right off. I ended up getting busy with other stuff and have not have a pressing need to get to the bottom of getting it working for our purposes. For us actually, exporting the flat pattern as a .step file works just as good. Our nesting software accepts .steps. If you end up getting the export of the .dwg/.dxf working, can you post here the key to getting it up and running. Below is a copy/paste from some assistance I received from the support team on what to put in the body but I just have not dug into it yet and tested.body = {<br> 'format': 'DXF',<br> 'view': '1,0,0,0,0,1,0,0,0,0,1,0,-0.001041696251729854,-0.03302,0.09414614537777849,1',<br> 'destinationName': 'Export Flatpattern via API',<br> 'version': '2007',<br> 'flatten': True,<br> 'includeBendCenterlines': True,<br> 'includeSketches': True,<br> 'sheetMetalFlat': True,<br> 'triggerAutoDownload': True,<br> 'storeInDocument': False,<br> 'configuration': 'default',<br> 'cloudStorageAccountId': '',<br> 'cloudObjectId':"",<br> 'partIds': pid<br> }
I think originally I was not getting it to work because I wasn't sure what to put in the "view" key. According to support, those numbers represent the top view of the flat pattern. Apparently now, we can just use the word "top" instead and it is supposed to work. Good Luck!
Edit:
I see that paste got converted into something. Here it is as text.body = {'format': 'DXF','view': '1,0,0,0,0,1,0,0,0,0,1,0,-0.001041696251729854,-0.03302,0.09414614537777849,1','destinationName': 'Export Flatpattern via API','version': '2007','flatten': True,'includeBendCenterlines': True,'includeSketches': True,'sheetMetalFlat': True,'triggerAutoDownload': True,'storeInDocument': False,'configuration': 'default','cloudStorageAccountId': '','cloudObjectId':"",'partIds': pid}0 -
I managed to get it to work, directly message me if help is required.
You cannot just list all parts and try to export them, non-sheet-metal parts will return 4xx. You need to identify flat patterns specifically using the insertables endpoint with includeFlattenedBodies=true:
Use deterministicId (from insertables), not partId (from the parts list). Export endpoints are keyed on deterministicId.
For the actual export step, use the official translations API (POST /api/v6/partstudios/d/{did}/w/{wid}/e/{eid}/translations with formatName: "DXF"). It's async — fire the job, poll /api/v6/translations/{jobId} until requestState === "DONE", then fetch the blob from resultExternalDataIds[0].
