Is there a custom feature for setting tesselation?
eric_pestyeric_pesty Member, pcbaevp Posts: 2,553 PRO
Tesselation quality can be configured but is done through "configured properties" so is a pain to setup for configurable/multi part part studios (have to setup every configuration permutation for each part)...
I was wondering if it could be controlled through a custom feature (similar to how the "part color" custom feature is a much better way of applying colors to parts than using the standard method...).
I figured I'd ask here before going through the process of trying to create a custom feature for it!
  • EvanReeseEvanReese Member, Mentor Posts: 2,832 PRO
    Not sure, but I don't see where you might change that with FS. Let me know if you find it!
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,553 PRO
    I did try a setProperty with "propertyType" : PropertyType.TESSELLATION_QUALITY,
    But that doesn't exist so I guess that's a no!
