Rotate part... around center of it self?
ognen_plavevski
Member Posts: 6 ✭
I'm trying to create this in OnShape:
So I made the single pole, and I'm getting stuck trying to create the two copies at an angle of 120 degrees.
If I try to rotate it, this happens:
I can only do the rotation on the edge, but not the center of the part.
Thus the replica is... not where it's supposed to be.
How would I do this?
Hey @ognen_plavevski, try selecting the cylinder face for your axis instead of that edge. Also, Cylindrical pattern might fit your need better than Transform.
