Struggling with corner joint/intersection
kamil_akamil_a Member Posts: 4
I'm working on modeling a building but I've been stuck on this issue since this morning.  I'm trying to join these semi-circular building facade mouldings to form a corner. To create these facade mouldings I extruded and then applied a full round fillet to make it semi-circular. I know this is rather basic, but I'm new to 3D modeling and I wasn't able to find a solution elsewhere in the forum.   Thanks in advance!
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,640 PRO
    Look at using a sweep feature instead with a semi-circular (or even circular if it doesn't interfere with anything inside). It can go around the corner in one step.
  • kamil_akamil_a Member Posts: 4
    @eric_pesty Thanks, that worked!
