view lock in drawing
EugenEugen Member, pcbaevp Posts: 19 PRO
I created a sheet with a number of views.
I finished it with some kind of text and so on.
Now I want to create some new sheets with the same views at the same place.
So I just copied the sheet and changed the configuration.
Now I want to make sure no one will be able to move any view at another place because every sheet should looks like the same (but the configuration details).
How to fix/lock the position of views?
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 578 image
    @Eugen Locking a view position is not possible at this time.  I've created a support ticket and will tie you to that improvement.
  • EugenEugen Member, pcbaevp Posts: 19 PRO
    Thanks a lot, Pete
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    edited March 2023
    @PeteYodis Thank you. Is there an option to choose to align the new drawingviews to an exisiting sheet like "align views to other sheet"?
    So I dont have to copy the old sheet and change the config.
    Best regards,
    Axel Kollmenter
