Pdf edit
svenolov_nystromsvenolov_nystrom OS Professional Posts: 85 PRO
I will make notes on a pdf import, but all text and markings is not saved, so the next time I go to the document, it is not there.
I might have missed something.
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
    I don't think Onshape is a PDF editor.
  • svenolov_nystromsvenolov_nystrom OS Professional Posts: 85 PRO
    It is possible to do some edits, add text, lines and color markings on pdf files. It is done with tools in Firefox or Edge,  It get lost when you close the document.
    Export and reload and your comments is there
  • S1monS1mon Member Posts: 4,046 PRO
    If you can replace files - such as PDFs - in an Onshape document. So you could edit a PDF using some other tool and then replace a PDF which is in the Onshape document.
    Firefox and Edge has it I think chrome also.
