loft between angled planes
henning_michel_
Member Posts: 19 EDU
in Drawings
Hi, I have two planes at an angle. On one plane there is a square. On the other there is a circle. I connect square and circle with a loft. The Loft has a twist. Why is that and how do I get rid of the twist?
The higher the angle between the planes, the more twist there is.
Thanks
Henning
Thanks
Henning
Hi @henning_michel_, The Match connections option within the Loft feature will solve this twisting issue:
https://forum.onshape.com/discussion/15381/improvements-to-onshape-january-25th-2021/p1
