How do I chamfer an edge so it is flat between two edges of variable separation?
nasheed_x
Member Posts: 2 EDU
This is what I currently have:
I want to make it such that the edge has been flattened like this:
Except notice that the two edges are a variable distance apart from each other. How can I make it such that the chamfer is flat edge to edge.
I'm not following what width(s) you want to control. Maybe a sketch on top of this? Do you want the chamfer to be a constant width, or what's left over from the original surfaces to be constant width?You are likely to need to make what you want in a manual way. Perhaps a constant width fillet, then a surface loft between the edges and some replace face or split.
Yeah I would avoid chamfer and loft a surface between the inner and outer loops then split the part with the surface.Senior Director, Technical Services, EMEA0
