Holes not lining up?
Hi. I am an occasional user of Onshape for small diy projects. I am working on a simple drawing with 4 parts mated together. There are 2 holes in each of 2 parts with a bush between them at each hole. One set lines up perfectly but the other doesn't. All the parameters are the same so I can't understand what is wrong. Any ideas?
https://cad.onshape.com/documents/5b3df14cccf95f03ae8ab887/w/6e4f40fcc04778bb37a2dd45/e/eb6106a87e31d3de3e0c36e5?renderMode=0&uiState=64165d9c3fb17b4c3df3e61f
steve_shubin Member Posts: 1,113 ✭✭✭✭
@riccardo_ingrosso
https://cad.onshape.com/documents/a1ef3f00a65c62a51f3596ef/w/f046564d95fdfa5187d1d4de/e/b7310393e275d33d7672865c
I saw your part studio prior to your fix. Something on the left was not 50 mm from the left edge. It was 49.xx
Take a look at the part studio in the document in this post
I sketch one point and then mirror across the right plane. Then use one HOLE feature to make all the holes0 -
nick_papageorge_dayjob Member, csevp Posts: 981 PRO
https://cad.onshape.com/documents/c13a608ef1a02cab542c1e51/v/10c1cfd97a1b63880e249c41/e/1d9329456667bf6c2d6d194a?renderMode=0&uiState=64171a993c265c40a7f69fdb
Try modeling it this way. The way you did it is not taking advantage of what OS can offer. The differences:
1) The parts are modeled in the positions they will be assembled at. This allows you to design in the clearances/contact the way you want between parts. It also allows you to share sketches for multiple parts (like the hole sketch).
2) It allows you to use one feature to make the hole through all the parts.
3) The parts are modeled symmetrically about the default plane. This allows the mirror to work for the second set of holes. Generally a good idea to model symmetrically.
4) No chance for things not lining up, like you ran into with a dimensioning error.
In the assembly:
1) All the parts come in at their intended locations. That means you just need to "fix" one, and group the rest.
2) Only one mate needed for the second roller.1 -
riccardo_ingrosso Member Posts: 9 ✭
That’s a great reply Nick and very informative to me. I certainly would never have worked out that bit about the mc’s being based on the centre of mass.The tip about placing everything in the sketch is also very handy. Thank you.0
In the assembly:
