Parts motion simulation
ricardo_raimondoricardo_raimondo Member Posts: 66 ✭✭
I am trying to verify the movement of a door, using a multiple-link hinge. I have Part1<1> and Par4<1> set as fixed. At this point, Part<5> moves following the restrictions of the hinge. Now, I need to "glue" Part5<1> to Part1<2>, to complete the simulation. I tried 3 planar mate between the parts, also fastened mate, but in any case, after doing the mate nothing moves. I guess I am missing some mate that will allow me to join Part5<1> and Part1<2> and simulate how the door opens. For further information here is the link to the document: https://cad.onshape.com/documents/adf5a9d499789107bac5e6f5/w/d675540f1b71b6e462ba6b84/e/d941e3da5bee6dc651ad29fd?renderMode=0&uiState=641b1e68c6abb63df4b2d3f8
I will appreciate any ideas on how to achieve this.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 882 PRO
    • You only need one mate (Fastened, Revolute, etc.) to define the relationship between any two parts.  In this case, just one Fastened mate between Part 1<2> and Part 5<1> will do it.  No need for planar mates unless you want the parts to slide relative to one another (2 degrees of freedm).
    • I would recommend only fixing one part.  Unfix Part 4<1>.  Leave Part 1<1> fixed.  Add a Fastened mate between Part 1<1> and Part 4<1>.  Use the Offset option to get the parts into the right orientation.
    • Rename your parts something descriptive.
  • ricardo_raimondoricardo_raimondo Member Posts: 66 ✭✭
    Thank you much, Matt. I'll try your suggestions.
  • Sinan_ArnautSinan_Arnaut Member Posts: 5
    You could have done some dynamic simulation using principia MBS directly within Onshape. This offers more of additional details, including time histories of positions, angles, forces, torques, and more. Plus, it seamlessly synchronizes with your Onshape assembly for added convenience and efficiency.
