Is it possible to make an inserted sketch containing an image in an assembly opaque?
StephenGStephenG Member Posts: 384 ✭✭✭
A more recent update to Onshape made an image inserted into a sketch visible in the assembly when the sketch was inserted. Previously, only sketch curves would show.
Because the sketch has a transparent quality it does not produce the effect I want.
Is there a way to make the backside of a sketch opaque so the image is only viewable from one direction?
  • shawn_crockershawn_crocker Member, OS Professional Posts: 928 PRO
    You could bring in a surface with the sketch and move it an infinitesimal amount so that it blocks the sketch view from one side.
  • StephenGStephenG Member Posts: 384 ✭✭✭
    Sketch will "bleed" through the surface. All instanced surfaces (regardless of it transparency value) are transparent with respect to a sketch.
    This behavior is also evident in a Part Studio.
    Update: The 1.175 - 2024-01-12 update adds the "Decal" function. The Wrap function allows an image to placed/wrapped onto a planer or cylindrical face.
