How to extrude a hole between two points (Sketches). It is on an angle.
jerry_scott022
Member Posts: 8 ✭
in General
Hi, how do I project a hole between two sides on an angle?
S1mon
Member Posts: 4,046 PRO
You can use the direction option to extrude along the angle. The cross section will only be round when parallel to the front plane. If you want a cylindrical hole, you’ll need a different approach.Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
S1mon
You can create a plane normal to the angled edge, and then sketch a circle to extrude, or sweep. You could also one of several custom features which will create a cylinder along a line, and then extend the ends and Boolean.Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
dirk_van_der_vaart
Member Posts: 561 ✭✭✭
A different approach, but working and editable
https://cad.onshape.com/documents/6579ad7b615ed02cffbc46cf/w/9f8e46cfe76a79c83e81968f/e/4ad0524cae3f1e0523f9c571
nick_papageorge_dayjob
Member, csevp Posts: 1,079 PRO
dirk_van_der_vaart said:A different approach, but working and editable
This does not result in a round hole. Here it is extruded at 45 deg instead of 10 deg so its more obvious:
A revolved cut would also work.
https://cad.onshape.com/documents/08471a5731a74634d6a659ac/v/6dc99031a97478d0004a870f/e/37c20aa4fd2b6dd6a6d49943
https://cad.onshape.com/documents/d6389404e9b8482d52ef79d0/w/2437d12157bd4cd98df32021/e/b06ffc24ca0c8215fd5d5eb5
This way you don't need any extra features or geometry:
F&P dishwasher part fits and keeps the rack in place. Thanks everyone.
