Winglets = problems
bart_v_abart_v_a Member Posts: 6
Hi, so I've started designing a hydrofoil for a testing rig. Basically real world testing to see how much lift, drag, etc. it generates. However since im not familiar with making winglets I just cannot figure it out. I'm using a profile, but for some reason it wont make it into one part after enclosing the winglet.
1. Winglets how to make them work
2. Connecting the winglets
https://cad.onshape.com/documents/c90b78366a0e5ee2c3a97c46
  • GWS50GWS50 Member Posts: 486 PRO
    Here's a version of the 'Winglet'. I have given the top a thickness in order to make a solid otherwise the end of the winglet is infinitely thin and won't boolean
    https://cad.onshape.com/documents/041e8f73d3a612b31a9d6d82/w/dba84b926591d76387cfe84d/e/2954f32559b45ae9f7b8d52b
    You might need some more guides to get a smoother transition.
  • michael_stallsmichael_stalls Member Posts: 65 PRO
    a winglet should be the same as a wing.you might need to split it up and use more guide curves to get the correct thickness and transition. The tip of the winglet should be an airfoil with a seperate tip that lofts to point. If that makes sense ...
  • irvin_pateirvin_pate Member Posts: 9
    @michael_stalls geometry dash bloodbath Choosing the right-wing profile is crucial for the performance of your hydrofoil. Consider using airfoil profiles specifically designed for hydrofoil applications. Common profiles such as NACA (National Advisory Committee for Aeronautics) airfoils or Eppler airfoils are widely used in hydrofoil design.
    @michael_stalls Choosing the right-wing profile is crucial for the performance of your hydrofoil. Consider using airfoil profiles specifically designed for hydrofoil applications. Common profiles such as NACA (National Advisory Committee for Aeronautics) airfoils or Eppler airfoils are widely used in hydrofoil design.
    Good idea
