NEW ONSHAPE EXTENSION - Renaissance Automation tools
caden_armstrong2
Member, User Group Leader Posts: 121 ✭✭✭
CADSharp has been hard at work to create a new suite of automation tools for Onshape called Renaissance!
Available in the Onshape App Store, start your free 30 day trial today.
The goal of Renaissance is simple: to save you time, so you can focus on what's important.
Measured Configurations - Creates a spreadsheet of measured variable values across a range of configurations. Works with the Onshape Variable feature
Release Export - Export all selected files from document releases
Assembly Export - Export component files from an assembly. Renaissance can even find component drawings and sheet metal flat patterns
Assembly Sharing - Share all component documents of an assembly
Configuration Export - Export all configurations of a part studio
Assembly Links - Generate a CSV containing links to every assembly component
Renaissance currently includes 7 powerful tools, with more to come.
Configured Drawings - Speed up drawing creation for configured parts. Starting with a source drawing, Renaissance will duplicate the drawing, updating all references for each configurationMeasured Configurations - Creates a spreadsheet of measured variable values across a range of configurations. Works with the Onshape Variable feature
2
