Sweep in multiple planes and angles
Good Morning.  I am struggling severely on this sweep project and would like some help please.  May I ask if someone would make step by step by step videos with sound on wire part 1,3,4,and 5?  Email the detailed videos to RMuirhead@pasadenaisd.org.  I am also trying to use the mirror command across/about a plane on path geometry on part 4 and 5 with out any success.
So embarrassed to ask the community, but I want to learn correctly.
Rod
rodm1161@gmail.com
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,898 PRO
    edited April 2023
    No step by step video but took a stab at wire 5 and got something pretty close. It looks like there might be some rounding errors as I end up with 6.44 instead of the 6.5 on the left on #5, and most of them are "over constrained" and you cannot get all the dimensions to match exactly. I guess these were drawn "by hand" and the dimensions just aren't exact (for example on #4 the 8.4 and 9 on the right do not produce exactly 135deg)
    The "ends" are also not really defined properly so there's a bit of room for "interpretation" unfortunately... I did manage to get really close to the total lengths by adjusting the end gaps.
    I guess it's a good example showing "real world" tolerances etc... but might not be ideal as an introduction
    EDIT: did the other ones as well in the same doc...
    https://cad.onshape.com/documents/18bc863c7c290924d91b0a14/w/8478d55258ad0dfcb1863d6b/e/f33a637e8785bf872f09a034
