why is the release management so slow?
René_Sartorio
René_Sartorio Member, pcbaevp Posts: 58 PRO
  • Axel_Kollmenter
    Axel_Kollmenter Member, pcbaevp Posts: 437 PRO
    edited April 2023
    We are trying to implement the release management to our workflow. But why is it soo damn slow?? I have spent all day so far creating the release candidate. It is totally lagging and just jerking. This is a very unsatisfying state.
    Best regards,
    Axel Kollmenter
  • sebastian_glanzner
    sebastian_glanzner Member, Developers Posts: 500 PRO
    Mmh, for me it is not slow at all  :D
    I frequently need to release multiple drawings across various documents on Onshape. To speed up the process, I open up to five documents simultaneously and click on the 'Release' button in each tab. By the time I return to the first tab, it's usually finished loading, which significantly reduces my wait time.
  • adrian_vlzkz
    adrian_vlzkz Member Posts: 317 PRO
    Following this thread.
    Haven't experienced slow performance, but definitely feel we are due for some significant improvements. As we grow our implementation the entire Release Process just feel as an unfinished solution.
    CAD Engineering Manager
  • René_Sartorio
    edited April 2023
    We were able to review the release process yesterday in another large project. There we had no problems with the speed.  In Axel's project, the release has been sent and the PC was left on overnight. This morning still nothing arrived at me. Feels like old CAD problems.
    @sebastian_glanznerwe know you would sent us an GIF. haha =)
    Could it be that it gets slower the more configurations are present ?
  • Axel_Kollmenter
    In my project, there are just a few parts and (sub-) assemblys but everyone with at least 25 configs. May the speed depends on the numbers of configs, like René said.
    Best regards,
    Axel Kollmenter
  • fnxf
    fnxf Member, User Group Leader Posts: 147 PRO
    @Axel_Kollmenter @René_Sartorio Have you shared yet with Onshape support through "Contact support"?
  • Axel_Kollmenter
    @fnxf no not yet
    Best regards,
    Axel Kollmenter
  • PhilippH84
    PhilippH84 Member Posts: 4 ✭
    having the same problem.
    At the moment it feels like I spending almost 10-15 % percent of time waiting for workflow transitions and release updates. 😴
  • Jack_Brentano
    Jack_Brentano Member Posts: 12 PRO
    I'm not sure why each configuration needs to be individually released. I have to disable release management for all of my configurations except for the main one.
    I don't know exactly how it works but I think every configuration you need to revision is basically duplicating each part it needs to load in the release management window, blowing up the load time.
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,277 image
    @Jack_Brentano It's very hard to tell without looking at your project, but perhaps if you are not treating individual configurations as separate parts from a release management point of view, you can use the "exclude from properties" option on the configuration inputs? Then BOMs and RM will treat all configurations as a single thing (using the default configuration).
