Yet another Update Drawings question
Jose_MontalvoJose_Montalvo Member Posts: 12 EDU
Hello,
I am having some trouble being able to update a drawing and assembly.
I have not made any versions and I have tried to delete the drawing of "Top Bar" to remake it but the measurement doesn't seem to change.
Below is the measurement I am after and the drawing that isn't updating..
  • Lucas_KuhnsLucas_Kuhns Member, csevp Posts: 109 PRO
    Your issue is that you are taking a measurement from an isometric view. Use the "Top" or "Bottom" view for this dimension.
  • Jose_MontalvoJose_Montalvo Member Posts: 12 EDU
    Thank you. I didn't realize that measuring points would change depending on the view.
    Maybe when we get MBD (model-based definition) this won't be an issue.
Howdy, Stranger!
