Sketch Constraints
joepjoep Member, csevp Posts: 27 PRO
Need some input on a sketch constraints: https://cad.onshape.com/documents/243759e1e879bb9d1153abc6/w/e853e1f7b66a29a6f7f32902/e/b9f0de5397bd7ae267e7af77
We would want to change (swap) the dimensions as indicated in red and retain the s-curve as shown. We tried several options, bounding boxes, circles etc. and get result as shown below (bottom).
Any input is appreciated.
  • S1monS1mon Member Posts: 3,327 PRO
    Arcs don’t like to be inverted in the sketcher. Depending on the exact shape you want, you could use a spline here. It’s much easier to go from the S going one way to its mirror.
  • joepjoep Member, csevp Posts: 27 PRO
    Hi Simon, Thats is what I figured. We will go the spline route. Thanks
