Convert an imported part generated drawing to a sketch
dario_sarradario_sarra Member Posts: 4 EDU
Some companies provide 3d drawings of their products but not DWG files. I downloaded the STL and STP files from Actuonix (https://www.actuonix.com/l12-30-50-6-i). I successfully imported them into a composite part and created a drawing of the resulting part. Now, I would like to convert the drawing views into sketches, but I can't find a way.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 882 PRO
    Not sure this is what you want, but if you export your drawing as a DXF, you can insert it (minus any text) into a Part Studio sketch.
  • dario_sarradario_sarra Member Posts: 4 EDU
    That worked beautifully, both with DFX or DWG. Thanks
