Export sketch to file, csv
jacek_zagaja
jacek_zagaja Member Posts: 47 ✭✭
Looking up for feature script that can export sketch to points in csv file. I must somehow tell script order of that points - I can man manually draw points on that sketch in order.
  • jacek_zagaja
    edited May 2023
    It's very useful if you need to export contours to 2D BEM software that don't use STL format. For example, AxiDriver uses diameter and delta_z as contour input, so I must calculate in Excel.
  • jacek_zagaja
    I've used the Dxf2xyz 2.0 tool to export points from DWG Onshape export, but polylines are not in order, unfortunately.
