Using a "library" parts workflow
leecaseyleecasey Member Posts: 36 PRO
Hi guys, so I have a library part. The library part has some configuration options which will be unique to every project I use it in. So what I'm asking is what's the best approach to create a new unassociated instance of this library part within my project?
I've tried "inserting" from another project but I believe this will keep association? or am I incorrect there? I can't seem to find a way to update its configuration variable though, screenshot below. (trying to edit the 500mm without it changing the original)
  • leecaseyleecasey Member Posts: 36 PRO
    Problem solved...I'll leave the post in case it helps someone else someday.
    I created a new configuration variable in the assembly and used the variable in the configuration variable at the part studio level.
    OK, just going to add some extra info. I can easily change the assembly configuration, but the configuration I want to change is on the part of the linear rail. Is it possible to add that configuration to the assembly level?
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,038 PRO
    Are you designing cnc machines by chance? I'm working on one for fun, outside of my dayjob.
