Trying to figure out animation with an engine block.
ede_N_ede_N_ Member Posts: 13 EDU
I'm working on a project thats independent from outside of my intro to engineering class and im trying to figure out how to animate the crankshaft and piston correctly as it gets stuck at 288 degrees for some reason and I can't quite figure it out, the link is below. Thanks!
https://cad.onshape.com/documents/a7db7002771dafcfc6ee1e89/w/438796e7a338ae7de57d6502/e/4cf21d2e2d4f6615598a04e6?renderMode=0&uiState=6458eabc0c21642abeaa0fa8
  • glen_dewsburyglen_dewsbury Member Posts: 1,252 PRO
    You have an unnecessary limit placed in the piston sub assembly that is stopping the rotation. After getting the main assembly to function there is still something odd in the animation. I think it has to do with parts themselves pushing limits.
    https://cad.onshape.com/documents/3000ed37d8e6a69f73507375/w/89ed91d79275e606415657cf/e/f1365b40e7b39c3f601fa71c
  • ede_N_ede_N_ Member Posts: 13 EDU
    If you could define the "unnecessary limit" that would be awesome, I appreciate the help. Yeah it seems that some of the parts have issues with size and length and ive been trying to figure it out
    also specifically why cylindrical mates if I may ask, just curious!
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,497 PRO
    Looks like you figured it out!
    It's best practice to avoid "over constraining" things, so for example if you have a mate that stops sliding in the z direction at one of a connecting rod, using a revolute at the other end is easier to "solve" than if it's another revolute that also locks the z motion even they can both be true at the same time.
    @ede_N_
    The unnecessary limit was angles on a revolute mate that stopped the rotation of everything in your main assembly. Noted from piston assembly. If the connecting rod hits the piston then review design.
    Use the simplest mate available at any given time. A cylindrical mate will let the piston moved up and down in the cylinder without restrictions. It will not create locks up with other mates like the revolute used in your connecting rod to crank. If the piston does not meet requirements (IE it moves past the top of the block) then your design needs updating not limits to restrict movement. Using a slider is more complex but not needed for limits in this case.
