Sweep disappears when I finish it
tom_combstom_combs Member Posts: 4 EDU
I have made a simple sweep and everything appears fine. However when I check the green check mark to save it. Everything disappears. I have tried this in a couple of different drawings.
  • S1monS1mon Member Posts: 4,043 PRO
    Can you share a link to a document or at least some screenshots of the preview?
  • tom_combstom_combs Member Posts: 4 EDU
    Thanks for replying. I believe I have solved it. When I made the sweep it came out in red. I have figured out that that is indicating an error. I just made a very simple sweep and it saved.  Steep learning curve for me.  :)
