Struggling with partstudio import "namespace"... (plus importing variable values from partstudio)
eric_pesty
Member, pcbaevp Posts: 2,936 PRO
I'm working on some "conceptual" featurescript that would involve importing sketches from different part studios based on user input (but the user doesn't directly select the part studio).
Basically the user would input a string and the featurescript would grab a different sketch for each character in the string and apply some transforms (with some base values corresponding to each "sketch").
I'm ignoring the whole string and selection for now and just jumping ahead to importing the sketch I understand I need to name an import and use that namespace later:
It seems like if I got the user to select a part studio I could use something like "definition.mypartstudio::build" but I'm unclear on how to create a variable that would reference the imported studio in the same way...
The second part I was hoping to do was to import the variables contained within the partstudio and do some math on that but I don't see a way to achieve that...
An alternate option I am considering is creating a structure (maybe an enum or table of some sort, I have a CSV with the values to match with each character so I would just need to add the reference part studio) that would store the values I need (instead of variables) as well as the corresponding "import" but I am not sure if/how that could be done...
If I had that I would just have to retrieve the correct sketch and associated values for each character in the string...
Import1::import(path etc...); Import2::import(path2 etc...);The part where I am getting stuck is how to "select" the correct import to instantiate. Basically how do I "set" which one to use when I do something like:
addInstance(instantiator, Importx::build,{etc...}I can't seem to use a variable instead of the "Importx" part above.It seems like if I got the user to select a part studio I could use something like "definition.mypartstudio::build" but I'm unclear on how to create a variable that would reference the imported studio in the same way...
There's no way to use a variable as a namespace. You could create a map with the various build functions, e.g.
const nameToBuildFunction = { 1 : Import1::build, 2 : Import2::build, ... };and then look up the correct function in the map. To get the variables in the part studio, you need to get the context it produces (run the build function) and call getVariable on it.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
const nameToBuildFunction = { 1 : Import1::build, 2 : Import2::build, ... };and then look up the correct function in the map. To get the variables in the part studio, you need to get the context it produces (run the build function) and call getVariable on it.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0 -
@ilya_baran
Thanks that helps...
I am able to create a variable "importedPS=import1::build" and then use that in the instantiator so that makes sense. The map idea above could work, I'll think about it, I'm guessing I should be able to add the values in there too if that made sense...
Can you elaborate on calling getVariable on "it"? How would I "getVariable" from the "importedPS" above? My fuzzy understanding makes me think the "context" part is where I have to point to importedPS but haven't had any luck yet...
Any thoughts on how I could put the import reference in a table or is that a bad idea?0 -
Update:
I figured out my issue with the getVariable!
I had tried:getVariable(importedPS, "variablename");
But I finally figured out I needed to add the "()" to get the actual context:getVariable(importedPS(), "variablename");
The map looks like it's going to work fine, I moved it to a separate featurestudio to clean things up and this would make it reasonably easy to "swap out" different "sets" in the future (if that came up...).0
