How do I print a document or drawing 1:1?
In the drawing, make sure the sheet is 1:1 scale. When you send it to your printer, make sure you have the printer scale at 100%, and also make sure the paper size in the printer dialog matches the Onshape drawing size.
To double check you got it all correct, put a dimension on your drawing, and after it prints out, measure that with a ruler.0 -
I just want to add to this from my experience.Do not use your browser to print. Onshape creates a PDF to enable printing most browsers will display the PDF but when printing your browser *may* still scale the print. mine was off by about 2%By using Adobe PDF Reader to print the accuracy increased dramatically. however still not exact.I use printing to make a paper template fro drill holes.0
Where am I supposed to make sure the sheet is 1:1 scale?
I don't see any place where it shows me that information. I can scale it with a scroll wheel at the print/preview dialog but nowhere does it show a % scale. FreeCAD does this properly and so does Fusion and NanoCAD, offering the ability to fix scale at the print dialog.
when pritting make sure Actual size is selected and not fit to printable area. In actual size, make sure it's set to 100%.
When in the drawing TAB double click on the Sheet in the feature tree on the left i.e. "Sheet1" and a dialogue box will open showing th sheet scale……adjust to suit
