How do I print a document or drawing 1:1?
mario_darceuilmario_darceuil Member Posts: 113 ✭✭
I wan to print a drawing in the ratio 1:1 or the same size as it is drawn. Please give instructions.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 973 PRO
    In the drawing, make sure the sheet is 1:1 scale. When you send it to your printer, make sure you have the printer scale at 100%, and also make sure the paper size in the printer dialog matches the Onshape drawing size.
    To double check you got it all correct, put a dimension on your drawing, and after it prints out, measure that with a ruler.
  • chris_notforpublicationchris_notforpublication Member Posts: 8
    I just want to add to this from my experience.
    Do not use your browser to print. Onshape creates a PDF to enable printing most browsers will display the PDF but when printing your browser *may* still scale the print. mine was off by about 2%
    By using Adobe PDF Reader to print the accuracy increased dramatically. however still not exact.
    I use printing to make a paper template fro drill holes.
