I need to have an Onshape doc (DXF) for cutting Polycarbonate windows. But I have Sketchup drawing
jf_hallewasjf_hallewas Member Posts: 2
Can I confert my SKP drawing to DXF?
  • Nath_McCNath_McC Member Posts: 136 PRO
    You would have to re-model the part in Onshape and export the DXF. Alternatively, if you can open the SketchUp drawing, you may be able to export that out into a different format to be read by Onshape
    It could be that wherever or whoever you got the SketchUp drawing from can export the DXF. Then you can import the DXF for future use.
