Counterbore at each end.
I have a part that requires a thru-hole with a counterbore at each end. The counterbores are of different sizes. My method is to use the hole tool to create the geometry. The issue is that you cannot use a thru-hole on both ends. One end can be counterbored with a thru-hole and the other has to be a counterbore with a blind hole depth or it fails. You should be able to thru-hole from both directions to get the right hole notes. Notice the image below has the bottom callout without THRU.
Twitter: @BryanLAGdesign
