Unable to transform / move spline
kieran_liptrot
Member Posts: 2 ✭
in Drawings
Hello all
I'm very green to onshape & I'm currently roughing out a part for some machinery, however when I drew the spline sketch its located too far down the top plane & i just need to move it up, I believe I have everything constrained correctly in order to move it but for the life of me I cant figure out how to make this line off blue. I know once its all done I can probably move on but cant someone point out where I'm going wrong?
Document: https://cad.onshape.com/documents/e0c845c5fc010061ba9d654a/w/eefbc8a5c92c598871edd7e0/e/f2a80e73bca8928ef9841ea7?renderMode=0&uiState=647cb96c5cf54f6c7769061e
location of issue: Outer path
Thanks for any assistance you may be able to provide.
It looks like you're trying to approximate an archimedes spiral with a spline though, in which case, here's a better way using the Helix tool. https://cad.onshape.com/documents/0a18d9c6c40a2ae86bb86c0b/w/99f4fd7ea4b78849623874c1/e/0696ef66c6856e1e466a13b9
