Screws won't fit
roman_herweg
roman_herweg Member Posts: 6 ✭
Hi there,
I saw some videos about screws by now but the screws and nuts wont fit. I'm not sure what I,m missing.  I am using the Thread Creator tool.
I tried to assign the exact ISO diameters to screw and nut but they won't fit. now I am trying full mm Numbers but it doesnt look like it will fit.
Thanks and Regards
  • _anton
    _anton Member, Onshape Employees Posts: 550 image
    In PLA and PETG, I normally print holes equal to the diameter of the screw (e.g., 4mm for an M4 screw) - then the screw just makes its own threads. If it's a through hole and the screw fastens to something on the other side, I widen the hole by 0.4mm.
    I've found that FDM-printing threads isn't terribly practical.
  • nick_papageorge_dayjob
    nick_papageorge_dayjob Member, csevp Posts: 1,257 PRO
    Are you trying to 3d print a part with threads? Then thread in a store bought screw?
  • michael3424
    michael3424 Member Posts: 783 ✭✭✭✭
    edited June 2023
    Which thread form (1/4-20 etc)?  Are you using the thread specs for standards that are listed in Machinery's Handbook?
    Keep in mind that 3D prints do not often print the exact dimensions specified.  If the threaded hole prints a little undersize and the male thread a little oversize, the former won't fit into the latter.
  • _anton
  • robert_scott_jr_
    robert_scott_jr_ Member Posts: 912 ✭✭✭
    Even with a resin printer I've never had any luck with threads even as coarse as 1/4-20. I know I will have to follow up with a tap. - Scotty
  • GWS50
    GWS50 Member Posts: 529 PRO
    I usually use threaded brass inserts for threads in prints. Heat them a little and push them into to kind of melt/weld them in place. Works well and is surprising strong. Also means you can use thread lock if needed.
